connection not secure
beeg
Re: connection not secure
Post by beeg »
Here's the instructions to disable this notification from FireFox.
"There is a hidden preference to turn off the warnings if they really annoy you and you think they'll never be of value.
(1) In a new tab, type or paste about:config in the address bar and press Enter/Return. Click the button promising to be careful.
(2) In the search box above the list, type or paste "insec" and pause while the list is filtered
(3) Double-click the security.insecure_field_warning.contextual.enabled preference to switch the value from true to false
(4) Assume this login could be easily stolen and avoid re-using it on important sites
So this becomes even more interesting. I did the config: thing and did the search and this is what came up:
ScreenHunter_47 Apr. 08 15.23.jpg (47.06 KiB) Viewed 1480 times
I have change nothing in this area and I do not see these warnings??????
ChrisNeilan
Post by ChrisNeilan »
I get that warning when I log on as I type my user name. I too ignore it.
Chris Neilan
rpd
Post by rpd »
I stay logged in all the time and only have to log in again if admin has been working on the system.
Not sure if the windows version is the same, I run Linux ;) , but in the upper left corner, next to the back arrow, there is a lower case "i" in a circle (information).
Clicking on the "i" opens this pop up window.
Screenshot from 2017-04-08 16-09-25.jpg (273.82 KiB) Viewed 1468 times
Click on the ">" to get more detailed information.
