Tailstock vertical or not
wa2crk
Re: Tailstock vertical or not
Post by wa2crk »
If you can set up your drill press function as follows you can use almost any method to hold the blank. A drill press vise or any tooling that will hold the blank securely.
wixie on the table.jpg (86.68 KiB) Viewed 4706 times
wixie on the sawblade.jpg (81.46 KiB) Viewed 4706 times
The drill bit MUST be 90 deg to whatever support table is used to support the work.
rpd
Post by rpd »
I horizontal bore my pen blanks using the table and the miter gauge to align the blanks, this has the advantage that you can then swap the drill chuck for the sanding disk to square the ends of the blank. Someday I'll make a jig that slides in the miter slot, that will be even easier. Here is a link to the thread showing the setup. http://shopsmith.com/ss_forum/viewtopic ... 69#p206969
drl
Post by drl »
I apologize for my slow response to you assistance--other projects have taken priority I think Ed's response probably is my answer and will be taken the next time I'm drilling pen blanks. I need to preload the flex in the tailstock when doing the alignment. I haven't been taking that into consideration. Doesn't take much when drilling pen blanks. Thanks to all.
Regards,
Dwight
Pre-loading is undoubtedly the correct approach. Consider some form of this:
Shown here are the legs of an extension table but the principle is the same.
drl
Post by drl »
Leave the wedges in during the drilling operation if I am understanding you correctly. I'll be giving that a try. Thanks.
Regards,
Dwight
drl wrote:Leave the wedges in during the drilling operation if I am understanding you correctly. I'll be giving that a try. Thanks.
Regards,
Dwight
I don't make many configuration changes on the machine where I typically use the wedges but I leaver them in (most all of the time).
