The reason for the 'paradox' is that universal motors create 'back emf' that limits running current. That 'back emf' is directly related to rpm.
Thus a motor running slow because of reduced voltage will draw more current. A pulsing controller helps reduce this and allows greater torque.
All this is a gross simplification.
Anyone use a HF router speed control with an angle grinder?
Re: Anyone use a HF router speed control with an angle grinder?
It provides some credible explanation for the behavior. It also shows that a speed controller can be a two headed monster, producing more heat and slowing a cooling fan.
My angle grinder has a variable speed trigger ??????? not sure of any benefit this would add ?
