No oiling holes?
Ron309753
Post by Ron309753 »
Terry,
I doctored up an existing picture (see attached) to show you what we are talking about. The picture is of the floating sheave, but the procedure is the same for the control sheave
The hole does not need to be precisely 3/16” from the raised collar; it just needs to be drilled over the keyway near the center of the entire sheave. 3/16” from the raised collar gets you close.
Sincerely,
Ron309753
Let me add that IMHO the hole drilling is best be done with the sheave removed from the headstock and shafts and key etc. Also be sure to remove any burr from the inside of the key slot due to drilling through it.
[quote="Ron309753"]Terry, I doctored up an existing picture (see attached) to show you what we are talking about. The picture is of the floating sheave, but the procedure is the same for the control sheave
The hole does not need to be precisely 3/16&#8221]
joefitz
Post by joefitz »
How deep should I drill the oil holes? Thanks.
beeg
Post by beeg »
joefitz wrote:How deep should I drill the oil holes? Thanks.
Drill a thru hole. This piic may help ya for placement of the hole.
http://shopsmith.net/forums/attachment. ... 1291385951
beeg wrote:Drill a thru hole. This piic may help ya for placement of the hole.
http://shopsmith.net/forums/attachment.htm?attachmentid=11103&d=1291385951
Drill them with the sheave OFF the shaft!;) Clean up any burr 'inside'.
