home made cross cut stop
robinson46176
Re: home made cross cut stop
Post by robinson46176 »
ARCretired wrote:Just a simple afternoon project
Most of my "Simple afternoon projects" now seem to take at least two days... :eek: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
I have "GOT" to get better organized...
john_001
Post by john_001 »
Nicely done!
(BTW, I think the MS browsers will display TIFF files, but Chrome and Firefox need a plug-in)
mountainbreeze
Post by mountainbreeze »
I needed something simple to do the other day so I took a shot and the Cross-Cutter jig too. I didn't have any threaded inserts on hand so I just tapped the hard maple block. I tried it out and it does work well. It took me a few minutes to figure out how to do the initial setup for a dado but after that, it was easy to use.
Jig Both.jpg (134.21 KiB) Viewed 9965 times
ARCretired
Post by ARCretired »
I like that. Easier to thread the wood (if is hard enough) than mess with threaded inserts. ARC
algale
Post by algale »
Well done!
That should work great as long as the threads in wood last. But, no sweat, if they do fail you can still use threaded inserts.
Squirt some thin CA into those threads. Helps durability. They will be tight initially.
You used 1/4-20 bolts?
mountainbreeze
Yep, 1/4-20 bolts. Also picked up some threaded inserts the last time I was at Lowe's and installed them.
