Not unless your stock is exactly twice the thickness of the round over bit radius.algale wrote:Is there a method (other than trial and error) for ensuring the round over is equal?
My sense is that if I carefully align the very lowest portion of the cutting surface of the bit (remember I'm using an overarm router) with the exact mid point of the stock, it should end up uniform and centered when I flip the work piece over.
Is that right?
I don't have an over arm router but the procedure I use on the router table should work fine, just upside down.
I use a SS ruler on edge and raise the bit so the bottom corner of the cove is flush with the table. The bearing will keep the other edge of the cove flush with the stock. You will always be centered regardless of the thickness of the stock. This way you will always get perfectly rounded over corners. Unless your stock is EXACTLY twice the dimension of the round over bit you wont get a perfect bull nose if that is what you are after. If the stock thickness is very close a little sanding will make it perfect.
With the over head router you don't need the ruler. Just lower the bit so the top corner of the cove is flush with the top of the stock. I make a test cut to be sure I have it correct. Tweek if necessary but usually only once. With a router table the stock thickness makes no difference when tweeking. I just use a piece of scrap. With the over arm you need a test piece the same thickness as the final stock.
What you want is the cove to just meet the surface of the stock. Too high and you don't get a complete curve. Too low and you get a square corner at the surface of the stock. Of course you know that because that is why you asked the question.
