Shopsmith Model 10E table saw turns slowly
rpd
Re: Shopsmith Model 10E table saw turns slowly
Post by rpd »
skou wrote:
rpd wrote:
otabe wrote:Hi, My dad has an old Shopsmith Model 10E that I am trying to get up to snuff and it has a table saw that turns at a very slow crawl that I'd like to fix. I don't know if the parts are old or if I need to adjust something.
Thanks if you can help.
Ok. first the saw blade should be mounted on an arbor, not in the drill chuck.
With regard to the speed, your speed changer is not set up correctly, here is a link to the manual for the speed changer. http://vintagemachinery.org/pubs/detail.aspx?id=2714
Ron, Keith Rucker says THANK YOU!
(Keith owns the Vintage Machinery site.)
steve
And I to him, :) VintageMachinery.com is a valuable resource.
What is a M11????? :rolleyes:
everettdavis
Post by everettdavis »
JPG wrote:What is a M11????? :rolleyes:
Must be a Mark II from Montgomery Ward
Everett
otabe
Post by otabe »
Thanks for the tips!
Everett
Think Mark 2 ! ;)
everettdavis
I'm thinking the M II Wards unit labled with the Powr-Kraft Branding but I could be wrong about what he is referring to.
Everett
Wards Mark II vs Magna Mark 2.jpg (112.17 KiB) Viewed 7634 times
I would refer to that as a Monkey Wards Power Kraft "CLONE". :D
everettdavis
JPG wrote:I would refer to that as a Monkey Wards Power Kraft "CLONE". :D
II Funny! Or would that be a funny II? Not good if you are trying to find parts on that one.
Everett
skou
Post by skou »
OK, looking at this picture, the speedchanger is set
to slow. Look at the belts. Belt from the motor
pulley is "small at the speedchanger," and the upper
belt is large at the speed changer. Both decrease
tool speed.
Crank the speedchanger knob. But, NEVER without
the belts moving. If not powered, put your sanding
disc, and rotate while moving the speedchanger crank.
steve
10 ER, stripped down.
