So lets get to the exciting part....... nae lets wait on that.
So I'm back on an old project that has sat unfinished for maybe a couple of years now. It is a fancy birdhouse. If I find the previous post I'll add it to this thread.
So this is what I'm starting with:
- 20180328_160001_resized.jpg (204.57 KiB) Viewed 10041 times
The first piece I wanted to make was one that would fit inside the octagon. The easiest way to do that was to trace the outside as seen here:
- 20180328_160329_resized.jpg (187.72 KiB) Viewed 10041 times
Now that is the same size as the outside of the box. To get it to the inside size I used a piece of the same stock the box is made of to reduce it by going face to face to face and ended up with this:
- 20180328_160538_resized.jpg (221.75 KiB) Viewed 10041 times
The resulting part is going to be pretty small and trying to cut it on the table saw trying to use just the miter gauge wouldn't be very safe. Yes there are other methods but you already know I want to use the GWSS. Here you can see the part in relation to my hand to get an idea of the size. The shaded area is what I want as a finished piece.
- 20180328_162112_resized.jpg (203.64 KiB) Viewed 10041 times
Now I had mentioned some excitement and you will have to check out this video to experience it. One of the cut offs managed to get into the back of the blade and BANG. Well you will see.
https://www.youtube.com/watch?v=vQKUew5sS3k
After this I realized that the riving knife wasn't in place............ So if you are going to do this then make sure you have it in place BEFORE you start.
- 20180328_171458_resized.jpg (197.66 KiB) Viewed 10041 times
So the small part is now finished and in the next post I'll make the top for the birdhouse.
