National Woodworking Month - How are you going to celebrate?
Re: National Woodworking Month - How are you going to celebrate?
Breaking teeth on the pinion gears? :eek:
OMG what size sledge does one need to do that? :rolleyes:
I don't know but I have restored two Mark 5's with broken Pinion Gears. One a Greenie from 1957 and the other a Goldie from 1960.
chapmanruss wrote:I don't know but I have restored two Mark 5's with broken Pinion Gears. One a Greenie from 1957 and the other a Goldie from 1960.
I'm thinking getting the posts cocked so the teeth are out of sync.
Then there is the acupucky thing.
The teeth on the posts were fine, no visible damage. When they were reassembled with the replacement gears they went together and worked smoothly. All damage (missing teeth) were on just the gears.
This is what the one set looks like. Each missing sections of two teeth. I couldn't find the other set but they were in worse shape.
robinson46176
Post by robinson46176 »
chapmanruss wrote:The teeth on the posts were fine, no visible damage. When they were reassembled with the replacement gears they went together and worked smoothly. All damage (missing teeth) were on just the gears.
Maybe they had been used as house jacks... :) :rolleyes:
