lathe tool holder ideas?
kb0ppy
lathe tool holder
Post by kb0ppy »
I build a 12x12" tray with 1x4"s, a masinite bottom about 1/2 way up, like a drawer, cut two half 1 1/2" circles on EACH side to set on the top way tubes of the SS. I put all my lathe tools and sand paper in it while turning with the lathe, either on the left side of the head stock or under it! Works GREAT!!!!!
BILL
deanthom
Post by deanthom »
I actually had something like that. I used pegboard, though, so that the sawdust had someplace to go. 8)
If I were doing that one again, I'd make the holes bigger so that bigger chunks of stuff could escape, too.
The other tool caddy that I build a long time ago and have rebuilt and repaired and rebuilt again was one that could straddle the headstock and swung below the bench tubes. Two pieces of 1x stock cut in hooks to fit the tubes, and wide enough to enable a 1/2" tool to slip between two dowels and be supported by a third. I can put about 6 or seven tools in there easily, but not the smaller handled ones. The little handles mean that the tools end up below knee height. No longer convenient to grab, defeats the purpose, no? And no place to put sandpaper, extra non-chisel tools like chuck key and hex wrench. Plus dummy made 'em out of the pine that he had in hand. They've broken several times and really should be retired to the burner.
Dean Thomas
KCMO
520, jointer, bandsaw, stripsander
paulmcohen
Post by paulmcohen »
How about if a few of you post pictures, some of the ideas sound really exciting but a little hard to picture.
I have the Autocad/Sketchup design for the Shopsmith one that I created.
I have not built it yet because I don't think it exactly meets my needs, some ideas may help.
[The extension zip has been deactivated and can no longer be displayed.]
rcoder
No can do
Post by rcoder »
I unziped it and tried to open it in sketchup to no avail.
deanthom
Post by deanthom »
Ditto. Hmmmm.Can't save it as a JPG file, can't export it into anything useful...
There are several freebie programs that will enable you to "print" to a PDF file, which most of us could then see.
One source is found at CLICK HERE.
Try that so we can see it! :)
Dean Thomas
KCMO
paulmcohen
rcoder wrote:I unziped it and tried to open it in sketchup to no avail.
I did it in AutoCAD and ususally have luck openning it in Sketchup. I think Autodesk has a free viewer on their site. Let me know if there is some other format I can upload it in.
paulmcohen
AutoCAD can output HTML (Try this)
I created an HTML page and it creaded a JPG
Chisel Holder.jpg (34.37 KiB) Viewed 25216 times
rflaherty
Lathe chisel rack
Post by rflaherty »
Greetings--
I made these two lathe chisel racks out of 3/4" birch plywood. One rack is for spindle gouges, and the other for bowl gouges. To prevent the racks from sliding, I place a small piece of the non-slip rubberized material that goes under throw rugs between the rack and one of the way tubes. When not turning, I store the racks on long pegboard hooks.
--Bob
Chisel-rack-1-low sm.jpg (54.64 KiB) Viewed 25204 times
Chisel-rack-2-low sm.jpg (55.27 KiB) Viewed 25189 times
Greenvilleguy
Post by Greenvilleguy »
Good idea! Thanks for the pictures.
ronhollenbeck
Lathe tool holder
Post by ronhollenbeck »
Here are a few pics of my lathe tool holder. I store it in a drawer when I'm not turning.
Ron
