Thank you guys for the replies! My table is much more sturdy now. I did not realize the casting on the pivoting side was hollow underneath. The links for assembly were very helpful. The sawdust sessions were slightly painful to watch. I flipped the machine vertical, snugged the setscrews behind the pivot. Flipped it back horizontal, still had a little play, back vertical, snugged again, put it back down and now its nice and tight!
The bandsaw has a little wobble if you grab it by the very top, but that's also a couple feet of leverage on your connection points.
New day, new problems. Before using the bandsaw, I noticed the blade on it was pretty rusty. Popped open the case and looked around. Blade was tensioned everything turned by hand, nothing was really loose or made any bad noises. I closed it up and turned it on. The bandsaw was louder than I expected. Not in like a "I need to get hearing protection" but just noisy. After running it for a min it started making a rhythmic "clicking" noise. I turned it off and pulled the cover to investigate. I couldn't find the noise moving the the wheels by hand. I got curious and started fiddling with things. I removed the blade and knocked the rust off wet sanding with wd40 and 800 grit sandpaper staying away from the teeth. The blade cleaned up pretty nice. Putting the blade back in I noticed some of the blade guides wheel bearing things were kinda sticky/rough. I had a can of white lithium grease laying around sprayed and spun them by hand and they freed up nicely I grabbed the blade and was using it to roll the guide and found my clicking noise! The guide near the blade tension adjustment had a small flat spot in it where the blade had rubbed. I presume it had got stuck, and wore a flat on that guide.
After dinking around sanding the blade, spinning things, adjusting loose things. and applying lithium grease I hooked the bandsaw back up. It was about as loud as it had been, then after about 10-15 seconds it got a little bit quieter. From turning it by hand, the only real noise I notice is from the blade guides themselves. (I did not mess with these, though I did check that they weren't completely out of whack, putting the blade in a bind etc.) I put the miter gauge up there for a fence and ripped a 2x4 with it. (It has a resawing blade on it) It cut very nicely. Oddly enough, with everything greased the clicking has completely subsided. I did not replace that roller bearing thing-a-ma-jig, but it is on my list of things to get.
Anyways thought I would share my small success with you guys. The bandsaw is working!
ALSO: Dust collection on the bandsaw... just cut a hole in the shroud and make a port for vac/proper dust collection?
