Lathe Chucks
rcplaneguy
Re: Lathe Chucks
Post by rcplaneguy »
I bought the G3 shopsmith bundle from amazon. Works great, very pleased. Good price too!
thunderbirdbat
Re: Lathe Chucks
Post by thunderbirdbat »
geocaljr wrote:I have inherited a SS Mark V and am researching chucks for small bowl & plate turning. The Nova G3 Chuck 30th Anniversary bundle looks like a good deal, but is this particular chuck adaptable to the SS? I’m a little confused about insert and reversible chucks. Is this bundle only for Nova lathes?
From looking at the description for the Anniversary bundle it is not compatible with the SS. The one in the bundle is threaded, the SS needs a 5/8" plain bore to fit on the quill.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
Re: Lathe Chucks
The 'shopsmith adapter' converts from 1 x 8 TPI to 5/8 smooth bore.
thunderbirdbat
Re: Lathe Chucks
JPG wrote:The 'shopsmith adapter' converts from 1 x 8 TPI to 5/8 smooth bore.
JPG, what adapter are you talking about? The Nova adapter I have for my G3 chuck is 1 5/16", I am not sure about the TPI but it may be 8. I know the description for the Anniversary bundle that I found online at Rockler states: " Though designed for the Nova Comet II Midi Lathe (#46457, sold separately), it can be used on any lathe with a 1'' x 8 TPI thread. This is not an insert style chuck. Cannot use an insert/adapter to change the threading."
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
Re: Lathe Chucks
IIUC ISNS
NOVA SS ADAPTER.jpg (79.67 KiB) Viewed 24592 times
A 1" x 8 TPI thread is on the outside that mates to the chuck internal thread.
That seems to contradict the later 'cannot' sentence.
thunderbirdbat
Re: Lathe Chucks
The ISNS adapter would be too large to fit the chuck in the anniversary bundle. I measured my ISNS insert threaded end at 1 5/16" with maybe 8 TPI as I did not measure the threads, hence why they state it cannot be used with this chuck. There may be some other company that makes an insert 5/8" plain bore to 1" 8 TPI but I do not know.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
rpd
Re: Lathe Chucks
Post by rpd »
As Brenda said, there are three different versions of the G3 chuck, one direct threaded 1"x8TPI, one direct threaded M33, and one that takes inserts.
https://www.teknatool.com/product-category/chucks/
Re: Lathe Chucks
thunderbirdbat
Re: Lathe Chucks
rpd wrote:As Brenda said, there are three different versions of the G3 chuck, one direct threaded 1"x8TPI, one direct threaded M33, and one that takes inserts.
Interesting as 1 5/16 converts to about 33 mm, that may be the insert size and I was slightly off on my measurement as my ruler was in 32nds. 1 5/16" = 33.3375 mm 1 19/64" = 33.29921 mm 1 9/32" = 32.5438 mm The brochure/manual for the G3 also lists a 3/4" 16 TPI direct thread option for the G3 chuck.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
geocaljr
Re: Lathe Chucks
Post by geocaljr »
Thanks for everyone's input. I'm surmising that the 30th Anniversary bundle is NOT appropriate for the SS and that I would require an insert type G3 with the 5/8" ISNS adaptor.
