Miter set screw stuck
So THAT's what's wrong with my old miter bar
Wow,
Good point on the threads inside the miter-bar. On looking I see my oldest one is pretty butchered inside.... I just ordered a new bar and the OEM tapered screws as well.
thanks,
thanks,
Chris
- perryobear
Jim,
I'm not a machinist but I will give some input and hope others will add to it (or correct me) as needed.
NPT is a tapered thread used primarily for joining pipe and fittings. It is (as you noted) a tapered thread meaning the overall diameter of the thread changes with the depth of the thread. This feature, along with a bit of sealing compound, helps lock the pipe and fittings together to form a pressure-tite seal (not our application). In the case of a 1/4" NPT the thread has, I believe, 18 threads per inch (TPI).
A drill size of 7/16" diameter, or there about, would be used to drill the hole that would accept the 1/4" NPT tap. Remember we are dealing with 1/4" pipe (i.e., an OD of .54")
NC is a straight thread meaning the diameter of the thread remains the same over its entire length. For a 1/4" NC thread you have 20 TPI (i.e., our old common 1/4-20 bolt). For a 1/4" NF you have 28 TPI.
A #3 drill (about 13/64") would be used to drill the hole to accept a 1/4" NC tap.
As you can see 1/4" NPT in addition to being tapered, is about twice the diameter of a 1/4" NC.
A plumber would certainly own a 1/4" NPT tap, but they are also included in many tap and die sets, so you may have a friend that does a lot of car or other machinery work that might have one in his set.
Last but not least you should be able to buy one individually at a good hardware store.
I will now let others take over while I ponder our miter bar application.
Dennis
Dennis
jmoore65 wrote:Bump - to see if anyone can share the size/thread count for the NPT tap.
Jim
That size should be on your exploded parts listing.
- perryobear
Hi Jim,
To this point nobody has jumped in to correct me but it appears to me upon further investigation that we should be looking at a 1/8 NPT thread. This thread has a TPI of 27. I was able to easily screw the 1/8 NPT tap into my miter bar about half way as shown in the photos below. I hope someone else can confirm this.
Just remember that since it is a tapered thread, it will matter which way you insert the tap (there is a top and bottom to the miter bar).
I think that my other comments about the NPT tap being much larger than the same fractional size in NC tap stills stands.
Dennis
Dennis
- 100_1839_WEB.jpg (25.15 KiB) Viewed 3683 times
- 100_1838_WEB.jpg (22.98 KiB) Viewed 3676 times
- 100_1837_WEB.jpg (26.69 KiB) Viewed 3670 times
Dennis,perryobear wrote:Hi Jim,
To this point nobody has jumped in to correct me but it appears to me upon further investigation that we should be looking at a 1/8 NPT thread. This thread has a TPI of 27. I was able to easily screw the 1/8 NPT tap into my miter bar about half way as shown in the photos below. I hope someone else can confirm this.![]()
Dennis
Looks like you have lined the information up well. I would now chase the threads, make sure the tapered screw SS #501401 is correct and usable then dab just a small amount of antiseize grease McMaster-Carr #1279K31 on the taper screw threads with a Q-tip. I have found that a nickles worth of pm on that little taper screw has saved me a lot of grief.
ldh
- Ed in Tampa
Timster68timster68 wrote:I have a slight different problem. I can turn the screw really tight, but the miter bar still moves - it never locks in tight. Anyone experience this before?
I was always taught by Shopsmith to tear a stripe of paper and wrap it around my mitre bar in the area of the screw to shim the bar into place. I thought everyone did this.
