Wax,oil,grease, what lubricant?
Re: Wax,oil,grease, what lubricant?
Hobbyman2 wrote: Tue Jul 05, 2022 6:18 pm See the manufacture recommendations on maintenance and lubricants ? In the pattern shop years ago we use to use graphite on the Big band saw bearings and the drill press , it did not collect saw dust and seemed to out last oil .
I believe you are replying to a SPAMer. If you look he is a first time poster to a 2008 thread ( typical SPAMer method ) and one of our great moderators deleted the included link in the post.
Hobbyman2
Post by Hobbyman2 »
jsburger wrote: Tue Jul 05, 2022 7:37 pm
Could be . it cold be a good topic to re-visit , I haven't noticed many people using graphite as a lubricant lately , If , I recall it comes in a small squeeze tube or a spray , it could help those who may wish to take advantage of something other than oil or grease in their band saw bearings .
thunderbirdbat
Post by thunderbirdbat »
Mix the powdered graphite with alcohol then use a small paint brush to apply a thin coat. Capillary action will help get the graphite into crevices. The alcohol evaporates leaving just the graphite. Used to use this when working on submarine steam systems.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
thunderbirdbat wrote: Wed Jul 06, 2022 2:48 pm Mix the powdered graphite with alcohol then use a small paint brush to apply a thin coat. Capillary action will help get the graphite into crevices. The alcohol evaporates leaving just the graphite. Used to use this when working on submarine steam systems.
Great tip, Brenda! I use graphite powder quite a bit, but generally apply it dry. Then I try to flush it into the shaft bores, etc. with WD-40 or similar, which makes an even bigger mess. Your technique should be much easier & cleaner.
Reason: Fix quote.
RFGuy
Post by RFGuy »
BuckeyeDennis wrote: Wed Jul 06, 2022 3:58 pm
I agree as well. I love using graphite for lubrication and will have to try this technique for getting it into hard to lubricate spots. Thanks Brenda!
📶RF Guy
Why would a moderator bother to edit out a link(or whatever) rather than simply not allowing the post to pass???
JPG wrote: Thu Jul 07, 2022 1:12 am
What forum policy was violated other than posting that particular link?
RFGuy
Post by RFGuy »
JPG wrote: Thu Jul 07, 2022 1:12 am Why would a moderator bother to edit out a link(or whatever) rather than simply not allowing the post to pass???
My guess is that some SPAM-like posts are innocuous, so the MODERATORS chose to remove the link but leave the post text behind just in case the post isn't SPAM after all. Less offensive to a potential new forum member to remove a link than to delete the entire post. I believe some SPAM posts are obvious and should be deleted, but there are some that are not quite so obvious. Not sure if this is the reason or not, but in any event, I want to thank all of the MODERATORS for their tireless efforts against the forces of SPAM here...
📶RF Guy
I guess you would have to ask the moderator. The post was somewhat on topic but apparently the link had a problem.
I like Brenda's suggestion on applying powdered graphite. I have used the spray type which uses a liquid carrier that evaporates but Brenda's suggestion may be better without over spray getting on parts where it is not wanted. Any aerosol product has the potential for over spray. A small, long handled hobby paint brush could be just right for reaching the worm gear on the Speed Control Assembly through the access hole on "B" and "C" Headstocks.
As for someone bringing back a nearly 14-year-old thread and posting a link, I too find that suspicious. Amita, if you are joining for legitimate reasons then welcome.
