joint matic
rpd
Re: joint matic
Post by rpd »
blades52 wrote:
Hi RPD, picked one of these up yesterday - would you mind re-posting that link? It is not working now.
This one should work. :)
http://www.lhdigest.com/SS/MANUALS/OTHE ... 555458.pdf
Re: joint matic
FWIW, Firefox gave a warning about the sight when I clicked the link.
Re: joint matic
My FF 'passed' it. ???
Re: joint matic
JPG wrote:My FF 'passed' it. ???
Do you have the Malwarebytes add on installed?
Re: joint matic
Worked fine for me. Downloaded the pdf and scanned it and it passed. But if it worries you then stay away.
Re: joint matic
reible wrote:Worked fine for me. Downloaded the pdf and scanned it and it passed. But if it worries you then stay away.
The PDF downloaded fine but FF blocked loading the web site page. Better safe than sorry. It does not worry me. That is why I have paid Malwarebytes and EsetNod Internet on all my devices.
If you read the cyber security sites you don't have to even click on things on a web site to get infected. I don't see that type of warning on my screen very often but if I look at the logs I see LOTS of web sites that were blocked. When I see an actual warning form ESET or Malwarebytes I take it seriously. These are cyber security companies that are top notch. I get daily updates to their security databases.
Do any of you remember a while back when Dusty was getting links in our posts for AD's? He had gotten bit by something he clicked on or downloaded that installed a PUP. Good security software (not the free stuff) mitigates that and lets you have piece of mind that you are protected.
I my opinion it is very much worth the money to not worry and angst over how something happened and how to fix it.
rpd
Re: joint matic
Post by rpd »
Fire Fox only flags that site as "insecure" because the site is "http" and not the newer 'https" which is encrypted. Until fairly recently this forum was flagged the same way.
The man who hosts that page is actually a member here, tucsonguy, and also runs the Facebook, Shopsmith Owners Group.
Re: joint matic
VS
https://www.lhdigest.com/SS/MANUALS/OTH ... 555458.pdf
See if your system is happy with the first one. The second one is the one you visited that gave you the error message and FF flagged that all by itself.
blades52
Re: joint matic
Post by blades52 »
Fantastic. It works now. Thanks a ton! This is going to be a life saver.
Shopsmith Power Pro Mark 7, Sawsmith 2000, Planer, Bandsaw, Belt Sander, Strip Sander, Jig Saw, Biscuit Joiner, Joint-Matic, Jointer, Mortise, Molder, Maxi Clamp, Scroll Saw, Shaper, Router, DC3300, Smithy Super Shop, Craftsman RAS & Bandsaw
Re: joint matic
rpd wrote:Fire Fox only flags that site as "insecure" because the site is "http" and not the newer 'https" which is encrypted. Until fairly recently this forum was flagged the same way.
OK makes sense.
