Time for a new installment of “what’s this?” I made a trip to my grandparents house and looked through my grandpas old shop. This came out of a drawer labeled “shopsmith.” I can’t find what it is or have any idea what it’s for. All that I know is that it slides in the miter slot in the table.
What Are These For?
Re: What Are These For?
- 3915DD11-EBB2-4ACE-ACA6-353959AFB9A2.jpeg (273.79 KiB) Viewed 4277 times
In the bottom image the part that is riding in the miter slot is part of the SS Dial Indicator.
https://www.shopsmith.com/ownersite/cat ... icator.htm
https://www.shopsmith.com/ssacademy/SS_ ... gnment.htm
I also see two sliding t-nuts and some hardware used to secure items in the SS miter slot and a (knurled nut - nice to have - I have a dozen or so with no assigned function - just available when needed).
https://www.shopsmith.com/ownersite/cat ... turesC.htm
Wow I love this group. Always has the answers.
I was talking specifically about the part in the miter slot, the hardware just happened to be in the table at the time.
Now time to see if I can locate the dial itself for purchase. Or another one that will mount to this piece. Because there’s no dial in all of my parts.
I use one that is shown in the attached link. Mine is the 1" Titon with a "lug back". Just about any dial indicator with a lug back will work on the base that you. There are many for which you can spend a lot more money but for what. Remember, this is a wood shop and not a machine shop.Meng88 wrote:Wow I love this group. Always has the answers.
Note the little red box in the image from the first link I sent. Stay of the lookout for that. It is a set of tips for the plunger in the dial indicator. Most of those tips you probably won't have a pressing need for but .....
Those tips will likely fit on just about any dial indicator that you might acquire.
I love this thread. I anxiously look to see what the new part is that needs IDed and then see if I know what it is before I read the answers. Fun thread guys.
in the photo from Fri Jan 03, 2020 5:16 pm the rod shaped item to the left sure looks a lot like the plunge stop rod and the indicator for my PC 690 router.
larryhrockisland
Could it be part of the SS Dial indicator set?cham-ed wrote:in the photo from Fri Jan 03, 2020 5:16 pm the rod shaped item to the left sure looks a lot like the plunge stop rod and the indicator for my PC 690 router.
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
Rock Island, Ok
1953 10ER
Another 10ER
