Shopsmith Mark 5.7 project
Re: Shopsmith Mark 5.7 project
No I do not think the missing selector plate(actually it is an interlock) caused your problem other than the missing interlock function.
I can send thee a key. ;)
Being a double cut, they are a bit pricey(requires a good locksmith with good equipment and work ethic).
Same key as Sawsmith [YPP].
FissionChips
Post by FissionChips »
JPG wrote:No I do not think the missing selector plate(actually it is an interlock) caused your problem other than the missing interlock function.
Thank you! I might take you up on that offer if I successfully refurbish it and can find the interlock plate...there was a box of random stuff that came with it so it might be in there.
On the topic of my Mark 5.7 project, I came across the thread where a user had found a Mark V speed control retrofit into a Mark VII headstock:
https://www.shopsmith.com/ss_forum/main ... 18445.html
I was wondering if you had heard the outcome of the damaged control sheave. It looks like something I'd like to attempt if it really is possible to do.
Thanks again!
