Magna Jigsaw Question
Re: Magna Jigsaw Question
Interesting. I wonder when this one was made.
That being discovered, what do you think that oil seal is? Could I make one with gasket material or do I need to purchase something similar to a rubber washer? I try to avoid purchasing smaller parts like that from shopsmith if I can help it because shipping costs more than the part.
Sent from my LG-H931 using Tapatalk
"Like a bull chasing the matador is the man left to his own schemes
Everybody needs someone beside em' shining like a lighthouse from the sea" - Brother, NEEDTOBREATHE
I cannot help. I have never seen one of your vintage. Anything I would say would be a wild guess.gloomis wrote:Interesting. I wonder when this one was made.
So wild guess #1 - use a rubber sealed bearing (Both sides) and insure the missing 'seal' is compensated for(LATERAL PLAY BETWEEN BEARING AND RETAINING CLIP).
If you measure the shaft size (ID) and the diameter of the hole it fits into (OD) and the width, space available between the bearing and end of the cavity, An industrial supply store of possibly an auto parts store should be able to find you one from the dimensions.
Got it! Thanks for everyone's help.
https://www.shopsmith.com/ss_forum/gene ... 5-s30.html
This post references part 74 and a replacement for it.
Same basic Jig Saw but the exploded parts diagrams are from manuals of two different era's. The only change to the Jig Saw from its introduction in September 1954, besides the color it was painted, is the change to eccentric mounting posts and the Trunnion Bolt Assembly. The Trunnion Bolt Assembly was later changed to a washer and 3/8" cap screw. I do not recall when that was changed and it could have even been a replacement option after it was discontinued. I would have to find the printed copy of those instruction for a date. It does lock the table angle on the trunnion easier. Sorry, back on topic. JPG's manual is from before the part numbers changed in 1964. They are the same parts just different part numbers and sometimes the description varied slightly. Any of the manuals from before 1964 have to be compared to a manual after that for the current 6 digit part number.
As with many of the parts for the Jig Saw since it was discontinued, Shopsmith no longer has that part available.
I have a Magna Jigsaw Mod 610 Serial# 82237 Mfg about June 1958 and my parts diagram looks just like the one above posted by gloomis. I too am looking for a shaft seal (#74 P/N502264).
JJ Rausch
Bradenton, FL
2017 Mark 7
1958 Magna Jigsaw
SS 11" Bandsaw
Bradenton, FL
2017 Mark 7
1958 Magna Jigsaw
SS 11" Bandsaw
Interestingly enough, I found this post from 2008 that has a source. It looks like the source is still good, but probably needs to order the item in quantity. I will try calling them to find out the pricing.billmayo wrote: Tue Nov 04, 2008 7:15 pm Good news, the Timken oil seals fit perfectly. The 2 oil seals were installed and no leaks. I wish I could say the same for my attempts at making housing gaskets. I will keep trying different gasket materials until I find one that does not leak. I will post my gasket making results when successful.
billmayo wrote:I have ordered both the #50 and #74 oil seals from:
URL: http://www.baumhydraulics.com
SKU Product Item price
00842194 314267N $4.79 NAT SEAL .625 X 1.000 X .125 TYPE 1 #50
00842356 340847 $2.94 NAT SEAL .500 X .750 X .125 TYPE 1 #74
You may want to wait until I receive them and make sure they fit. I will post the results.
JJ Rausch
Bradenton, FL
2017 Mark 7
1958 Magna Jigsaw
SS 11" Bandsaw
Bradenton, FL
2017 Mark 7
1958 Magna Jigsaw
SS 11" Bandsaw
So the oil seal by National Product posted above is no longer available from Baum Hydraulics, but there is another seal with the same dimensions by SKF Item# 4912 (http://www.skfextranet.com/catalogs/457 ... asp?s=4912) and it's carried by Grainger under Item# 40J912. I ordered qty=2. The next question is has anyone replaced this seal??? What is the procedure???
JJ Rausch
Bradenton, FL
2017 Mark 7
1958 Magna Jigsaw
SS 11" Bandsaw
Bradenton, FL
2017 Mark 7
1958 Magna Jigsaw
SS 11" Bandsaw
woodshopnerdery
- Silver Member
This post was a life saver to me this week. My jigsaw developed a huge leak and I needed to replace this seal to keep some Christmas crafts going. As jjrausch suggested I ordered the SKF 4912 seal form Grainger. Installed it and works beautifully, no more leaks so far. I make a video about the process here.
https://youtu.be/PKZ6FyCIzLg
