Fan style trellis
- SkullsquadronX
Re: Fan style trellis
Bainin.
The problem was the telescope leg in between the two tables, wouldn’t let me get the fence any closer to the blade on either side. That’s way used a longer pipe and a third telescope leg and pushed the tables together.
DLB.
I did and would if I had a third fence, on that note I need to say I put a Christmas order that has a M7 Fence Ext kit which would work has that.
I do have one of the top fence feather boards, but want to have one behind the blade as well in the in front to make it less likely to kickback.
I did see your post on them before last week and was worried I mite have the same issue. I gently started putting it together and had no problems with it. I don’t have a micrometer to check for ya. I got them in Marchs sale .
Algale.
I got six floating tables and two extension tables so I could do set ups like this. I’m still thinking of getting two more and two more sets of the infeed/outfeed extension brackets.
DLB.
Algale.
Bingo!thunderbirdbat wrote:I thought that was one of the major advantages of the SS. The ability to adjust the tool to meet any challenges of the work required just needs a good imagination and additional parts or jigs.JPG wrote:
Yep! Tinkertoy/erectorset mentality survives.
- SkullsquadronX
Well I jump in and cut one board up. Now comes figuring out the fan part of the project. My Aunt wants a three foot spread.
This is where I’m at now.
- 7AD4D73E-D470-442A-A932-39DD50104C5F.jpeg (138.38 KiB) Viewed 4949 times
Here is an option with 2 sets of telescoping legs using the Extension Table Brackets.SkullsquadronX wrote:I started setting up my 1st Shopsmith up to rip a PVC board in to 1” stripes. I decided to use my new Infeed/Outfeed Extension Table Brackets to do this, along with the second fence from the other Shopsmith. I was using four of my floating tables with the telescope legs in between the floating tables, now realizing that that not going to work on the infeed side with the second fence.
The second picture shows a huge table without the Extension Table Brackets.
- DSCF0453 (640x480).jpg (96.48 KiB) Viewed 4947 times
- DSCF0456 (640x480).jpg (106.52 KiB) Viewed 4947 times
- SkullsquadronX
Ya I came to that conclusion after a while jsburger.
- 7FA3BB91-3ABF-4112-A596-1DA390EF809A.jpeg (111.35 KiB) Viewed 4945 times
- SkullsquadronX
So today I was lay out my the fan after here the size of the fan. Not sure what looks better? Im trying to decide to go with all seven strips or just five?
My Aunt wanted a three foot wide top and not sure what looks better?
- FFA4E6F9-2867-457A-9D5F-331BBBDFFC3C.jpeg (160.74 KiB) Viewed 4765 times
- 385E7410-809D-46DA-8E37-B95F6713DA90.jpeg (160.26 KiB) Viewed 4765 times
- SkullsquadronX
I do if it was a four foot. The three just looks to close and the five to far apart.jsburger wrote:I like 7.
Oh my Aunt chose the five, my mother like the seven also.
- 6A6BEA9A-7B53-4639-B6FB-9D7D153A2406.jpeg (157.03 KiB) Viewed 4751 times
- BBEB9907-1CB3-49AA-9B76-798F9C07C77D.jpeg (159.53 KiB) Viewed 4748 times
- 59FC37D5-878B-4B28-A225-C0304BBFE8A0.jpeg (160.74 KiB) Viewed 4748 times
- 1F4A42CF-DB16-4950-B091-C5390318D7CA.jpeg (160.26 KiB) Viewed 4748 times
Now you have spread them different widths. I still like 7.SkullsquadronX wrote:I do if it was a four foot. The three just looks to close and the five to far apart.jsburger wrote:I like 7.
I think either 3 ft would look better if the straight portion was about a foot longer.(the fan portion is shorter, but the same final width) It would appear similar to the 4 ft fan then.
