quill has no tension
rpd
Re: quill has no tension
Post by rpd »
Jacob Anderson on the quill advance
https://www.youtube.com/watch?v=MihGNw1OQPU
farley
Post by farley »
I used Jacob Anderson's video and it was a great help.
I posted the link before. here it is again.
https://www.youtube.com/watch?v=YbHVTwSp9DI&t=272s
the link in the above post goes to a camping video.
so I took it all apart and struggled for hours to get the spring on the keyhole. getting the screw in the slot was the worst.
back together, nope heard a snap.
apart, the screw not in the slot.
back to step one ... all together, Nope popped out again. So I believe I will just order a new part as that must be the issued in it staying together
thanks all for the help.
hopefully when I get the part, my last post will be "successfully'
john
Shaping the spring keyhole end so it nearly matches the shaft profile helps.
Then 'forming' the spring away from the end so it positions the keyhole etc. past the shaft(bears against it) then it becomes 'automatic' reentry.
farley
Post by farley »
new spring and housing came quick, I could see where the new setup was tighter and shaped to the shaft bette.
only a few curse words and got it on and it working correctly, thanks for all the help.
j
ps
Dusty take care it's still tucson hot
john
