Congratulations!
That is one fine looking door!
John
Front Door Refresh
davebodner
Re: Front Door Refresh
I assume your door with surrounding sidelights was installed as a single piece when the house was new. It's probably even easier to install the whole unit in a rough opening than to precisely hang a single door.bainin wrote: Thu Oct 14, 2021 10:10 pm Yeah- we got a quote from a "door" installer , actually 2 different ones. Both told us that they don't simply install doors...no they bring in the heavy lifting equipment and replace the entire door/frame and surrounding accent windows etc as a unit. They were ranging in installed costs of $6000-10000 which was way more than I was willing to throw at a door. The argument is its the only way they can ensure their insulation ratings or whatever the that they quote. Uh huh. For that much money I could put up solar panels and run the AC and heat with all the windows and doors wide open
davebodner
I built a wood storm door. I had to order the clear fir, and I prepped it myself on the Shopsmith and Shopsmith planer. I used standard mortise and tenon joints. Then, I painted the outside and clear-finished the inside. I think it's imperative to make sure all surfaces are sealed with something. Since the door went up this Spring, I took a hand plane to one section of it. Did the wood move? Was it always out-of-square? Who knows? But, it's been great ever since.RFGuy wrote: Fri Oct 15, 2021 10:34 am Just wondering if anyone has built their own wood doors for their house before? I have thought about taking it on, but not sure I can get lumber dry & straight enough to attempt it. Anyone have experience with this?
My dream is to build old-fashioned double-doors for the garage.
Thanks Dave. Good to know. My double front doors need to be redone on my house and still trying to decide whether to go forward with it or not. Definitely worth considering, but I know it will be a pain to hang if I don't replace the door jam along with it.davebodner wrote: Thu Oct 28, 2021 12:18 pm I built a wood storm door. I had to order the clear fir, and I prepped it myself on the Shopsmith and Shopsmith planer. I used standard mortise and tenon joints. Then, I painted the outside and clear-finished the inside. I think it's imperative to make sure all surfaces are sealed with something. Since the door went up this Spring, I took a hand plane to one section of it. Did the wood move? Was it always out-of-square? Who knows? But, it's been great ever since.
