Motor problem
paulmcohen
Motor Problem
The 1 1/8 hp motor was introduced in 1962.
http://www.shopsmith.com/ownersite/faq/markv.htm
This was sometime during the transition from the anniversary model (brown/gold/tan) to the smooth gray model.
- Ed in Tampa
Dustydustywoodworker wrote:Thanks Ed. That clears up a lot and it seems to be a logical analysis of the motor problem that started this thread.
Isn't a starting capacitor usually housed in a container on the outside of the motor body? If so, my shopsmith motor has no such housing.
The electrical characteristics on my motor are:
A. 13.2 SFA 13.2 AMB 25 degrees C
In a different location, I have the following markings:
1 1/8 hp 3450 rpm SF 1.0
Do you know what SF stands for.
I searched online but my computer skills are limited. I've been told that indirectly two or three times my someone here on this forum. I am getting better but maybe not smarter as I grow older.
Sure wish I had been as curious when I was younger but I had no time to learn the small stuff then.
___________________
Making Sawdust Safely
That one made me look! SF stands for service factor and a 1 basically says it will perform at it's rated Horsepower. Service factors are usually 1, 1.15, and 1.25. If the service factor is exceeded the motor will heat up quickly and fail.
According to my serial number, I have a 1961 with a 1-1/8 hp motor and the poly-b belt system. When I was cleaning it, I was surprised to see there was no housing to hold the capacitor to the motor but rather, a small metal clip that was intended to wedge it against the end plate that houses the starting contacts. I was also surprised to find that my capacitor wires were soldered directly to the contact assembly, as opposed to newer motors which have clips so the capacitor can be removed for cleaning / replacement more easily.
I've been gone and missed all the followup answers. Thanks again for the information. Interestingly, I tried the motor later and the more I used it the better it seemed to work. So I suspect it might just need a general service and lube from sitting idle. But I might go ahead and give it a complete rebuild; from the advice here it doesn't seem like much of a chore.
I did look for the more powerful motor on purpose; it seemed like a worthwhile upgrade.
Cheers again, everyone who helped.
