Or need some kind of adapter(5/8" bore to chuck thread/taper).cincinnati10 wrote:Almost everything is exclusive to Shopsmith. The 5/8 headstock spindle with reverse tapered flat is on no other machine that I know of. Even on the machines that have a No 2 Morse taper, the chuck is threaded on or friction fit onto a taper.
I am not the all knowing machine expert. But I can't find any accessory that is standard on others machinery and which fits the SS headstock unmodified.
If I were to stock up on some parts.......
mesae wrote:Can't find the 3328A. Found a 3326A. Was 3328 a typo?
It appears tat you might be looking for a chuck key to be used on a 10E/10ER.
If you have a Mark V that needs a key, I think you want a 3326. Following are two pages for a website that has both:
http://www.tylertool.com/jacobsk30.html
http://www.tylertool.com/jak32thhachk.html
Other than the 17 most frequently ordered Shopsmith Mark V Parts, I would suggest the following parts if you do any repairs and which I find missing or damaged:
#124 Sheave Spacer that goes behind the fan sheave on the motor shaft. Prevents Fan Sheave from contacting the motor plate. Damaged some times.
#111 Retaining Loop #504187 goes on end of control sheave bearing. Included with new Control Sheave.
#112 Rollpin #513734 Retaining Loop fits in rollpin. Included in new Control Sheave.
#73 Spring #504196 Goes behind Speed Control Dial - easy to lose
#75 Washer #501631 Goes on Headstock Lock Assembly - easy to lose
3326A is correct. Key is K32(1/4" pilot).mesae wrote:Can't find the 3328A. Found a 3326A. Was 3328 a typo?
http://www.jacobschuck.com/images/produ ... ENG)-1.pdf
- robinson46176
Stock up on parts?
Do you mean that everybody doesn't have a shed full of parts machines?
Remembering back to the farm/ranch. Not nearly as many parts and stock as the farm! Not enough room! The "Shed has become storage for the LOML's keepsakes that will not fit into the house. Keepsakes and "parts" don't mix very well.robinson46176 wrote:Stock up on parts?
