Shopsmith 11 Inch Bandsaw refurbish
dgale
Re: Shopsmith 11 Inch Bandsaw refurbish
Post by dgale »
Just curious if folks who have installed new SS rubber tires used the glue or not? I was watching Jacob Anderson's video about bandsaw maintenance, and he said he felt the glue was unnecessary and that he always just installs the new tires on cleaned up wheels. I just put my new (rubber) tires on and they do stretch tight and it's hard to see them slipping. I can easily add the glue if deemed necessary but would make future replacement easier if I don't. Just thought I'd check on other folks' experience.
soonerNC
Post by soonerNC »
Thanks very much dgale and Russ for the info. I'll check back in if I have any issues.
I did a thorough cleaning of the bandsaw this weekend. I found a nice video on youtube where someone did a complete disassembly and cleaned it up. I will get the bearing upgrade from SS.
What do you all think of the guide rollers from Carter?
http://www.carterproducts.com/band-saw- ... th-bandsaw
I have had the Carter roller guides on my band saw since Carter first introduced them many years ago. They work perfectly and I have never had any problems with them.
Others here will have a different opinion. However, I will still recommend them and would buy them again.
soonerNC
Post by soonerNC »
Thanks John! I've seen the MyGrowthRings video about them. They seem better than the metal ones that I have.
soonerNC,
I have not used the Carter Roller Guides so I will defer to John on that recommendation. I do use the Cool Blocks Blade Guides instead of the original metal ones.
dgale,
I glue the rubber tires on. Even though they seem to fit "tight" when installing them I believe they could come off once they heat up during use. This has even been a problem reported by some users of having the Urethane Bandsaw Tires which do not use glue.
edma194
Post by edma194 »
I'm using Carter roller guides. They don't work with 1/8" blades as they come, but turns out they can be modified to use them. Much better than Cool Blocks IMO.
