Raising saw table to clear blade before sliding table
stew
Re: Raising saw table to clear blade before sliding table
Post by stew »
Thanks for the tip, the finger touch method worked for my 520 system.
Matanuska
Post by Matanuska »
Should have said I have a 520 table.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
rogersk
Post by rogersk »
Matanuska wrote: Sun Sep 11, 2022 9:15 pm Should have said I have a 520 table.
I was disappointed it didn't work for my Model 500, but it's still a good tip. If I ever get a 520, I'll be using it. Thanks for posting it.
Keep in mind the original M5 design was for a 9" blade and the MV 500 for a 10" blade. I do not think the MV 500 mounting posts are different from the M5. That means an additional 1/2" elevation is required.
jwwrguru
Post by jwwrguru »
For people who ponder the acquisition of a slide... They are superior to a normal table saw. My saw is almost no degree in comparison to a few of the more extensive and higher-quality slides I've utilized, but the same guidelines hold.
db5
Post by db5 »
jwwrguru wrote: Sun Sep 18, 2022 1:42 am For people who ponder the acquisition of a slide... They are superior to a normal table saw. My saw is almost no degree in comparison to a few of the more extensive and higher-quality slides I've utilized, but the same guidelines hold.
What does "acquisition of a slide" refer to?
spam coming!
