That 'vertical' piece that separates the two "halves" of the workpiece being rip sawn. That prevents the two "halves" from closing the kerf gap behind the blade. The splitter referenced to was the riving knife attachment. The upper guard has a similar vertical piece that in that instance passes all the way through the kerf of the workpiece. The reason for the riving knife is to provide that separator function when making a rip cut that is not full depth.steverboss wrote: Tue Jan 10, 2023 3:46 pmPardon my ignorance, but exactly what is the “splitter” you refer to?algale wrote: Sun Jan 08, 2023 3:28 pm I had that issue. Called Shopsmith and they advised me to basically flex the cams. Of course it snapped the rivet and so now I don't have functioning cams. Worst part was it was a brand new upper saw guard I bought from the factory. I'll not buy another. I use the splitter almost exclusively. Some day a Shark Guard.
Table saw blade cover anti-kick back feature jams
Re: Table saw blade cover anti-kick back feature jams
This is the riving knife from Shopsmith and it is part #556223:
https://www.shopsmith.com/ownersite/cat ... _knife.htm
The "Non-Thru Cut Riving Knife" which I leave in the lower saw guard at all times and use for through cuts and non-through cuts alike.steverboss wrote: Tue Jan 10, 2023 3:46 pm Pardon my ignorance, but exactly what is the “splitter” you refer to?
