Hello from Michigan
MichiganTom
Re: Hello from Michigan
Ok, thanks for the reply.
Since you own one, where would I find the serial number, looked briefly but didn't see one. I expect the manual to arrive tomorrow or Monday.
The sn is on the vent plate surrounding the lower spindle. Your vent plate appears to be absent.
On the left side of headstock around the lower aux output shaft. The number is stamped on the round tin plate(3"?)dia. Mine is 405025.
SS Mark VII(sn 405025), SSband saw, SS 4" jointer, Older SS Mark V w/DC treadmill motor,
Smithy SuperShop 720, Powerkraft RAS,Craftsman RAS, Ridgid TS2412 Table Saw,
Delta 12" planer
Delta 12" planer
MichiganTom
Yes, no plate on the lower left spindle, I was curious if some where their might be a stamp, possibly in the casting.JPG wrote: Sat Jan 28, 2023 11:06 pm The sn is on the vent plate surrounding the lower spindle. Your vent plate appears to be absent.
MichiganTom
Pictures of pieces and accessories that came with the unit.
MichiganTom
br549
For easier viewing, I rotated the pictures for you. HINT: Taking the pictures in horizontal or landscape mode usually doesn't require any photo-editing or manipulation before posting. And, you can preview your post before submitting to ensure the pictures will appear as intended.
- 20230129_113419.jpg (104.5 KiB) Viewed 1669 times
- 20230129_113500.jpg (125.91 KiB) Viewed 1669 times
- 20230129_113703 (1).jpg (128.29 KiB) Viewed 1669 times
- 20230129_113716.jpg (147.71 KiB) Viewed 1669 times
MichiganTom
The manual arrived today, it also includes supplemental sections, parts manual section. It's a restored manual from Everett Davis, (V1.02). Since you mentioned Mr. Davis and his thread.lahola1 wrote: Sat Jan 28, 2023 11:51 am Welcome to the forum. Here is a link to a recent thread on replacement rack pieces on Ebay and how to replace the rack.
viewtopic.php?t=31888
Also , you will find a ton of info on all things Shopsmith in Everett's, thread at the top of the maintenance and repair section.
Click the " Shopsmith Large Format drawings" thread ,then click the RED "my Google Drive". There you will find all things SS info including a section on the 1960's SS Mark VII's.
MichiganTom,
Unfortunately, the copies of the manual you purchased on ebay are not from Everett but someone profiting from Everett's work. Sadly, it is difficult to impossible to stop sellers like this. For anyone needing Manuals for Shopsmith tools look at other resources first and don't buy copies from ebay sellers. Almost all of those are available somewhere for free just like Everett's contributions here.
Something I noticed in your pictures is the #2 Moorse Tapper Lathe Drive shown in the red oval in the picture below. This is not useable on a Shopsmith of any model. Many stand-alone Lathes use these for their drive ends. I am not sure what the item is in front of the Drill Chuck. It is nice to have the Live Tailstock Cup Center.
_ .
I have not owned a Mark VII yet but I am sure JPG and lahola1 will continue to be a great resource for you.
_ .
Did your Mark VII come with a lathe chuck? The gadget to the right of the Morse taper drive looks like a SS adapter for one.
