Yes, The Mark V is as easy to use for ripping as a stand alone table saw. In fact it may be easier and more exact than many of them. The models 510 and 520 have a very good fence. Both fences lock on both the front and rear of the table and are very stable.putttn wrote:... Is the SS as easy to use in the table saw setup as a regular TS? I'm really challenged in both experience and room to work. .... I don't have the room for a dedicated table saw and not sure I even need one since I have the SS.
I think maybe you are concerned about short stock ripping. Using the Shopsmith Fence Straddler and the upper saw guard/splitter, short stock can be ripped very easily.
There are limits however. If you wanted to rip a board shorter than the length of the exposed blade (7 to 9 inches), the only force holding the workpiece up to the fence will be the side of the blade and the downward pressure from the straddler. This is definitely not an ideal situation and you should be clear of the kickback zone.
If you want to rip a narrow strip from a short board there is an additional issue. If the Fence straddler will pass through the space between the rip fence and the upper blade guard - you are O.K. If the straddler won't fit then you must set the fence so the desired piece is the portion cut off.
The complaints I have read dealing with ripping on the Shopsmith are related to ripping long stock. Here you are advised to have some type of support for the outfeed length of the board.
