Fear not! Links to YT are acceptable.tfrayne wrote: Sun Jun 25, 2023 9:24 am The outfeed support is a direct copy of Scott Markwood's YT video here:
https://www.youtube.com/watch?v=8KE7U2GrsZ4&t=7s
Not sure of the policy of linking YT videos on this forum, but if you paste that into your browser and replace the (dot) with a . it will work.
It uses ShopSmith T Nuts to attach to the rip fence. The holes are indeed to reduce weight. The material is 3/4" phenolic that I had left over from another project. I've just gotten into the habit of using the support legs whenever I have the machine upright.
The one thing I would do differently is to make little "feet" protruding from the edge of the support piece where it touches the table. It would be intuitive to snug the fixture up to the table but this causes the rip fence to hang up when making adjustments to it. I think if it had two little nubs to touch the fence instead of the whole leading edge, it would slide more smoothly. To remedy this, I just need to remember to pull it back about 1/8" before tightening down the T nut bolts.
Great Idea or Just Madness...
Re: Great Idea or Just Madness...
Thanks! Took me a while to understand what you were saying about the "feet" but I see your point.tfrayne wrote: Sun Jun 25, 2023 9:24 am The one thing I would do differently is to make little "feet" protruding from the edge of the support piece where it touches the table. It would be intuitive to snug the fixture up to the table but this causes the rip fence to hang up when making adjustments to it. I think if it had two little nubs to touch the fence instead of the whole leading edge, it would slide more smoothly. To remedy this, I just need to remember to pull it back about 1/8" before tightening down the T nut bolts.
It really is handy and I end up using it all the time; and not just for sawing. Anything going past the end of the table can easily be supported.
If you like I can post some photos of the fixture in another thread. But I take no credit for it. I just copied what I saw Mark do on YouTube!
And the first circle is cut.
But that's all for this weekend. Cut my finger on the chicken coop screen. Bloody band aids and glue mix, but not well....
IT IS I, ENSIGN PULVER!!
AND I JUST THREW YOUR STINKIN PALM TREE OVERBOARD!!
Thanks, JPG!
Swiley3362
- Bronze Member
Looks like an interesting concept. It will be interesting to see it when it is completed. I have built a cabinet with pull out trays that stores my jointer, bandsaw, jigsaw, belt sander, and lathe tail stocks. I have been adding hangers for table extensions on the outside of the cabinet (I can take new pictures to share later). I have included a couple drawers to house smaller components (drill bit kits, router bit kits, drum sandpaper, etc.). I have also built a tray under the bench and way tubes on my Mark 7 to manage my accessories. It sure beats laying components around the shop (and trying to find later).
Mark 7 Tray.pdf- (2.93 MiB) Downloaded 912 times
SS Cabinet.pdf- (1.22 MiB) Downloaded 978 times
Yes, please!tfrayne wrote: Sun Jun 25, 2023 6:28 pm It really is handy and I end up using it all the time; and not just for sawing. Anything going past the end of the table can easily be supported.
Well, one of the circles folded up a tad. I am debating whether to save it with a backing piece or start over and use thicker boards. I am leaning towards starting over because 40" seems a bit small for what I'm shooting for. Next one will be 44"-46" and nearly twice as thick.
But I did get the hardware yesterday. I will include a photo of that later. It's 36" in diameter and rated for 850LB
In the meantime, here are some pictures of my Scott From MY GROWTHRINGS inspired outfeed support fixture:
It attaches to the rip fence with two SS T nuts and a 1/4-20 bolt with a 7/16 bolt head. I use a nut driver that I keep on the accessory shelf to install and uninstall it.
I made a chamfer on the piece that attaches to the fence to allow space for sawdust. I did make holes in the outfeed support piece to reduce weight.
Oops - that was supposed to be another thread....
Thanks for posting the pics of your fence extension/outfeed table!
I am going to have a pause on this project. My planer (DW735) threw a chain and it broke two links. It is an older model I bought used and abused a few years ago. I will repair it and hand it off to my son. In the meantime I ordered a new one from Home Depot. With military discount it was $540. That's without the infeed/outfeed tables because I can transfer parts from the old one to the new one.
The day it broke, I went back to the house to sulk and browse CL for another used planer. Did not find one.
However..... I did find a Mk V 500 greenie!
Asking price was $140 and that seemed fair because it came with a model 610 jigsaw. Brought it home to put next to my 520. I think it will make an excellent slow paced project.
Spent a few hours cleaning to get it to a point where it "presentable." From the looks of it, I will need at a minimum a new power cord, new wheels, all of the panhead screws, one accessory mount lock, a tailstock and everything associated with the table saw besides the table itself.
I tore into the jigsaw yesterday and I find no evidence of it ever having oil in it. The white plastic yoke was broken. I may have done that by slowly spinning it by hand. But it was otherwise very clean inside with no oil residue of any kind.
Not sure about the jigsaw's age, but looking up the Mk V SN it shows to be a 1956. I have ordered a reproduction manual for it and a 3D printed yoke.
- greenie 01.jpeg (81.75 KiB) Viewed 21107 times
- greenie 02.jpeg (81.42 KiB) Viewed 21107 times
- greenie 03.jpeg (83.27 KiB) Viewed 21107 times
