OPR & "Flee" applied to veneer job
nuhobby wrote:Well, this continued with some "design on the fly" to become a Tea Serving Tray (attached). There's a few things I'd do better if I knew what I was aiming toward from the beginning, but aren't they all (projects) like that....
Happy Woodworking,
Pretty Good On the fly design! Thanks for sharing it!:)
Happy Woodworking,
I was going to give you a great big atta boy when seeing the nifty job you did with the top, but at that time it didn't have a use.
Now that it is in a Serving tray - ATTA BOY, CHRIS!!!:D
a1gutterman
Post by a1gutterman »
Nice look, Chris! I like the "handles" and the contrasting colors. :)
Tim
iclark
Post by iclark »
absolutely beautiful!
what are the sides made out of and what finish did you use?
inquiring minds...
ER10 awaiting restoration
nuhobby
Materials & Finish
Post by nuhobby »
inquiring minds...
Folks, thanks for the kind compliments.
For materials, I used hard maple for the sides. For finishing, most often I finish the last layers with water-based polyurethane since it is almost odorless. But this is a case where for the early layers of finish I use something 'organic' which penetrates deeper and looks richer. So, for the walnut veneer, I had spray shellac followed by brushed poly. For the maple I had one layer of wipe-on oil finish, followed by brushed poly. (Some time back I learned that water-based poly alone doesn't look very rich on walnut, especially at the end-grain, where it can look almost white.)
I've yet to see if the tray may be too 'slick' for serving tea... one day at a time!
Chris
iclark
Post by iclark »
Chris,
thanks for the follow-up.
Ivan
Gene Howe
Post by Gene Howe »
You could always glue down some of that shelf lining rubber stuff....:eek: :eek: :D
Gene
beeg
Post by beeg »
pkni wrote:You could always glue down some of that shelf lining rubber stuff....:eek: :eek: :D
Which I use to keep objects from sliding when hand sanding it.
