10ER Lathe dust collection and leather skirt
Re: 10ER Lathe dust collection and leather skirt
Can’t always get what you want… what I wanted and what I got
- IMG_0282.jpeg (69.18 KiB) Viewed 3662 times
- IMG_2691.jpeg (580.78 KiB) Viewed 3662 times
I may be old but I’m slow
https://www.schmuckatellico.com/
https://scshiftknob.com
They use the same material for 4" Dia. as they do all the way up to 24" Dia. and bigger. They use the same picture as well so getting a refund. I'm leaning towards horse trough for next attempt.
Reading 'specs' (when present) helps prevent that!
That said I cringe when 'specs' tell me what size box it comes in and little else useful.
Wow, the custom bench and tool storage features here are really impressive! Then I saw your pristine Mark VII with its own wood accents in the background, and was further impressed! Great work…Mike wrote: Sat Aug 05, 2023 3:38 pm The leather is going to be for skirts on each side to keep tooling clean down under.
John Dalton
Massachusetts
1948 10E, S/N 5052 (restored)
Massachusetts
JPG- only spec was Dia. + pic, I should have called as I ended up calling to get a refund anyway. Waste of time but I’m retired so that’s something I hope I have plenty of.
jpdalton- thanks for the kind words
Up skirt and down skirt pics + pic of pretty sturdy watering bucket, 2’ Dia., I hope to make into dust shroud
- IMG_2726.jpeg (696.08 KiB) Viewed 3441 times
- IMG_2727.jpeg (744.35 KiB) Viewed 3441 times
- IMG_2728.jpeg (466.49 KiB) Viewed 3441 times
More sturdy == harder to modify == better results.
In addition to having 'more' time, acquiring 'more patience' helps one's mind set.
Patience is very much a learning process for me but I agree with you.JPG wrote: Sun Aug 27, 2023 6:47 pm More sturdy == harder to modify == better results.
Got everything cut and it came out really clean, gorilla taped edges till rubber gas line comes in. Used a nibbles to cut out bottom and a Kett saw for horizontal cuts. Both worked really well with right set up. Still need to work out mounting and dust port locations.
- IMG_2761.jpeg (421.3 KiB) Viewed 3321 times
- IMG_2759.jpeg (609.29 KiB) Viewed 3321 times
Mounting method in progress
- IMG_2780.jpeg (523.5 KiB) Viewed 3273 times
Finished up dust shroud and trying to figure out best port locations. I have one on top to hopefully keep the finer dust away from me. Thinking of just a 4” hose and a smaller “big gulp” at bottom. My thinking is it would catch a lot at position shown + easy to move around once in awhile similar to vacuum or a better location than shown. Look forward to any comments or ideas.
- IMG_2839.jpeg (605.88 KiB) Viewed 3101 times
- IMG_2841.jpeg (690.37 KiB) Viewed 3101 times
- IMG_2843.jpeg (487.21 KiB) Viewed 3101 times
