Workbench Retractable Casters
CreekWood
Re: Workbench Retractable Casters
Post by CreekWood »
Oh, just in case anyone else ever finds themselves in a loosing battle with the feed belt on one of these old drum sanders, here's the radical adjustment needed to make that belt track correctly:
Get rid of the outermost adjustment screw on the side the belt insists on wandering towards, and force that end of the out feed roller down. I was so ready to kick this thing to the curb before I found this fix.
Mark V 500 upgraded to 520
Delta 36-725 TS
Kobalt Sliding Miter Saw
Bosch 1617EVS & Router Table
Craftsman 351.23371 Planer
Performax 16-32 Thickness Sander (finally tracking right!)
...and a growing collection of traditional hand tools.
I am curious WHY this worked.
This Is a feed conveyer belt?(slow)
CreekWood
Post by CreekWood »
JPG, I can't figure out why a band saw blade will ride on the crown of the wheel instead of flying off in the first revolution! And I tried that too-I applied electrical tape on the middle section of the drive roller, but that didn't help. I can't take credit for this fix; someone described it in another forum. Unfortunately I didn't keep the reference, because I'd sure like to thank the guy. I guess that in some conveyer belt situations, a tech will put a slight twist in the belt by canting an end roller. The standard fix gets argued-- some say tighten, others say loosen the tension on the side that the belt drifts to.
Oh, and a shocking story-- together with the shop vac, this drum sander puts a lot of static in the air. I wasn't all that surprised when the hairs on my arm stood up, or when it zapped my finger, but when the nose pads on my reading glasses started arcing I about went cross-eyed!
Delta 36-725 TS
I wonder it it riding on the lip has anything to do with it.
It IS a conveyer belt?
Ever heard of a Van De Graf generator?
CreekWood
Post by CreekWood »
Yes, essentially the drive belt is a conveyer belt made up as a loop of cloth-backed 16" wide sandpaper. Feels about 220-320 grit.
Had to look up Van De Graf; yep-I've seen those but didn't know the internal workings.
Delta 36-725 TS
roy_okc
Post by roy_okc »
@CreekWood,
Thanks for the link to the casters. The heavy duty ratcheting look like just the ticket for one of my CNCs when I redesign/enlarge/rebuild it and maybe also for a metal table I recently bought.
Roy
Laser engraver
