FORUM LINKS
DLB
Re: FORUM LINKS
Post by DLB »
RFGuy wrote: ↑Mon Dec 18, 2023 1:58 pm Would like to understand how they fixed some links in past threads and not others. I gave an example above. Can someone else take a look and confirm? For me, the link to my past thread gives a 404 Error. Thanks.
Yes, I get a 404 Error on that link also. (https://shopsmith.com/ss_forum/viewtopi ... he#p265642)
RFGuy
Re: FORUM LINKS
Post by RFGuy »
DLB wrote: ↑Mon Dec 18, 2023 2:07 pm Yes, I get a 404 Error on that link also. (https://shopsmith.com/ss_forum/viewtopi ... he#p265642)
David,
Thanks. So, I don't understand what ADMIN did when JPG forwarded another thread with a broken link to them. Did they just fix a particular type of broken link or selectively edit the threads that JPG forwarded to them???
πŸ“ΆRF Guy
Porter Cable 12" Compound Miter Saw | Rikon 8" Low Speed Bench Grinder w/CBN wheels | Jessem Clear-Cut TSβ„’ Stock Guides
Re: FORUM LINKS
I do not understand WHY some links worked for a brief period. There may have been some testing being done????
I hope an all inclusive repair activity will occur.
Why too much past effort is being lost if not!!!
There are at least two types of 'breakage'. (t= p= )
β•ŸJPG β•’
β•šβ•β•β•β•
Re: FORUM LINKS
JPG wrote: ↑Mon Dec 18, 2023 4:48 pm I do not understand WHY some links worked for a brief period. There may have been some testing being done????
The forum data is not being lost. Search for the subject, the author or both and with a bit of patient scrolling you'll find the data.
admin
Re: FORUM LINKS
Post by admin »
The above link https://shopsmith.com/ss_forum/viewtopi ... he#p265642 should now work.
Earlier I had added a redirect for /ss_forum, this one needed a redirect for /ss_forum/viewtopic.php (everything after the ? is a pass through).
If you spot others, let me know and I'll add them.
Shopsmith I.T.
Re: FORUM LINKS
[https//WWW.shopsmith.net/forums/showthread.htm?.....] needs to be redirected to:
[https//forum/shopsmith.com/viewtopic.php?.....]
β•ŸJPG β•’
β•šβ•β•β•β•
larryhrockisland
Re: FORUM LINKS
Post by larryhrockisland »
Looks like the links leading to the Shopsmith academy don’t work yet. http://www.shopsmithacademy.com/SS_Arch ... rn_Pt2.htm
I think the website for All In One Wood Tools is old or has changed.
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
RFGuy
Re: FORUM LINKS
Post by RFGuy »
David, JPG, ADMIN,
Thanks. I can confirm that the link issue I reported is now fixed. Much appreciated. I will poke around and see if I can find any other bad links on past threads. IF I do, I will report them. Thanks again.
πŸ“ΆRF Guy
Re: FORUM LINKS
β•ŸJPG β•’
β•šβ•β•β•β•
larryhrockisland
Re: FORUM LINKS
Another one
https://www.shopsmith.net/forums/showpo ... ostcount=4
This may relate to JPG’s post above, please disregard if redundant. :)
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
