baddlad wrote:just curious, where do I get new ones? Or can I reuse the old ones?
I did a search on Home Depots website and couldn't find them.
Jeff
Reuse them.
baddlad wrote:I wanted to clean up all the rust on the caster parts, so I was going to take them completely apart, and there is some kind of hollow pin that holds the bottom rod in place. Has anyone taken that out and how do you do it, without damaging things? Does it need a special tool? I was just going to try to jam a nail in there but thought I better ask first. Thanks in advance for any help on this.
Jeff
charlese wrote:Good point Mike! - - Or -- Don't take all of them apart at the same time! That way you can compare the dissembled one with the one that's still together:D
I think the 'original' rods HAVE two holes!;) Makes them ambidextrous!charlese wrote:I had similar issues when making the control rod - the one with the pedal - out of 1/4" rod. Had to be careful where I flattened areas for the set screws in the cams. Also had to drill two holes for the pedal rollpin in order to get it right.
