Francis, I read your post about lubing bearings with great interest ! I wonder, have you ever done the lower bearing on the Shopsmith band saw? After removing the lower wheel-shaft-bearing unit off the saw, I pulled the lower (spoked) wheel off the shaft with a 3 arm puller and it was EASY ~rumor was it was impossiblerobinson46176 wrote:Actually that statement is quite wrong. I have been relubing sealed ball bearing assemblies both for myself and professionally since around 1972. ...
(to be fair here I will say that the design may be different on other year models, mine is a '59 Magna, and the shaft/wheel LOOKED pressed in rather than molded as one piece.)
...so now that I have a smaller part to work with (It's like an auto water pump bearing), would you recommend the heated submersion in the electric motor grease ?
Yes, for me it's one of those "What would Francis do?" moments
I appreciate your knowledge
John ~S.F. Bay area
10ER #39030 (+ 3 more), Mark V 1980, 10ER Jointer, A-34 Jigsaw I'm testing, 10ER SPT mount for Bandsaw, Belt sander, Scroll Saw
