PTWFE 13 lathe duplicator
SDSSmith wrote:No, that is not fair to say. The brackets that mount to the table and hold the tubes have two hole sets in them. You use a different hole set depending upon whether you are mounting the table in the 500 carriage vs. the newer carriages with the wider tube spacing.
So, as stated before the old 500 table may be used with the duplicator brackets as a replacement table.
AH SO! Unfairness noted!!! Thanks I would NOT want to unintentionly/ignorantly misead anyone.:o
By assuming and asking if correct, one learns many things.:)
Thanks for the photo, Rob!:D
