Universal lathe tool
HopefulSSer
Re: Universal lathe tool
Post by HopefulSSer »
...And there's a flange on the tailstock insert which, when the tailstock is mounted normally, takes the pressure exerted by the quill. With it backwards, the flange is pushed away from the housing and all that would hold it in would be 1 little setscrew.
(Aside: Later tailstocks had two screws. You could drill and tap yours for the second screw, symmetrical to the first.)
Greenie SN 362819 (upgraded to 520), Bandsaw 106878, Jointer SS16466
