501325 Sheave - Control Assembly Shopsmith VII
jafpanda
Re: 501325 Sheave - Control Assembly Shopsmith VII
Post by jafpanda »
Measured against both sides of the control sheave.
(180-144) / 2 =18 degrees
I’ll have to remove the bearing before measuring the shaft, sleeve, and bearing seat depth.
I tried setting the protractor to 142 to see if the angle could be 19 degrees, but it wasn’t even a close fit.
jafpanda
Post by jafpanda »
Here is an update on progress…
3D hard surface models created in Blender software.
Item 13, 501324 Assembly - Idler Shaft (nut, washer, shaft, 2x bearings, 2x spacers, eccentric, set screw, 2x E-Clips)
Item 14, 501320 Key
Item 15, 501207 Sheave - Idler Shaft
Item 17, 501325 Sheave - Control Assembly (Cam Follower, 2x roll pins, bearing, over molded sleeve, sheave)
GetterDone
Post by GetterDone »
I remember this work you were doing.
Great info. :cool:
Dwayne
jafpanda
Post by jafpanda »
Thanks Dwayne 👍
