Handle pulsation when quill is extended at low speeds
Matanuska
Re: Handle pulsation when quill is extended at low speeds
Post by Matanuska »
I've been thinking some more about this and now I'm leaning toward Ed's resonant frequency vibration explanation. Doing a bit more reading it appears gyroscopic precession forces are a response to a torque applied at right angles to the axis of rotation. Gravity might do this as the quill is moved in or out in the horizontal boring position but it wouldn't explain pulsation in the vertical drill press mode. Whatever the explanation, deburring and waxing the quill and tightening the setscrew have fixed the problem for me.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
