Greenie power cord replacement?
billmayo
Post by billmayo »
hunt0168 wrote:It needed/needs a lot of cleaning up and some work. So far I've replaced the control sheave assembly, idler shaft, had the bearings in the quill, Gilmer drive and motor replaced, new belts and working on the power cord. The speed control is functional, but the "PORKCHOP" is worn and shows signs of being mistreated, and needs replacing as well.
After replacing the bearings on the gilmer drive I kind of wish I waited? The gear is pretty well worn in and I fear it will chew up the new belt. I found a drive assembly with gilmer gear @ Battles Hardware that they said is in great shape for $120, but funds are depleated at the moment. I thought about switching to poly v drive as there seem to be many reasonably priced parts selling on ebay etc, but would kind of like to keep it original.
Thanks again, and I'll gladly listen to all the information you guys can shell out!
I find the Greenie headstock is excellant for MINI and SHORTY Shopsmiths. I add oiling holes to the earlier Greenie's Control and Floating Sheaves. I cut an access hole under the LOGO cover if not already there and do other modifications to this heavier duty headstock. I have available modified Speed Control Assemblies and Gilmer Drive Sleeve Assemblies with a rebuilt and tested Gilmer clutch that I use. I have instructions and pictures for doing these modifications if interested.
If you have any questions, wants or needs, I will be happy to respond. Thanks. Have a great week.
eartigas
Greenie, shortie, etc.
Post by eartigas »
Bill:
I would also be interested in the photos and instructions you mentioned as I am reviving one Greenie with the Gilmer belt.
If you prefer you may wish to use a private message.
I have learnt a lot from your posts. Thanks for been so open with your knowledge.
Ed (NY)
Carmel, NY
hunt0168
Post by hunt0168 »
Bill, I too am interested in your modifications and drawings. I am also interested in possibly making a deal on a Gilmer sleeve and speed control etc. I'll send you a Private Message later when I get out of work.
