Mark 7 by 220v
Re: Mark 7 by 220v
RFGuy wrote: Wed Jul 30, 2025 6:22 pm I thought that the NEMA ratings on plugs and receptacles were just that "ratings". In other words, they specify max voltage and amperage, but they don't explicitly indicate the intended application.
I researched this a little more. It turns out that I was apparently wrong about the NEC requiring that NEMA connectors be used only at their specified voltages. And I also had my memory refreshed that that those NEMA-specified application voltages are not actually "maximum" voltages.
Once I figured out a good query ("Does the NEC require that NEMA connectors be used only at their specific rated voltages?"), Google AI came up with a concise and seemingly logical synopsis:
No, the National Electrical Code (NEC) doesn't explicitly require NEMA connectors to only be used at their specific rated voltages in all cases, but it does mandate that different voltages and circuit types on the same premises use different, non-interchangeable receptacle configurations.
This prevents mismatches that could lead to dangerous situations like fires or electrocution.
Here's a breakdown of the key points:
* NEMA configurations are primarily about safety and preventing improper connections, not strict voltage ratings for the devices themselves.
* The NEC focuses on ensuring that different voltages within a facility have unique receptacle configurations to prevent people from plugging equipment designed for one voltage into an outlet supplying a different voltage.
* While not directly prohibiting using a higher-rated NEMA connector for a lower voltage, it's generally best practice to stick to the intended rating to avoid confusion and potential safety concerns.
* Using a lower voltage with a NEMA connector designed for a higher voltage is generally acceptable, as long as it doesn't violate the non-interchangeability rule.
* If you do use a connector for a lower voltage than its NEMA designation, labeling it clearly is crucial to prevent accidental misuse.
In essence, the NEC prioritizes safety through non-interchangeability of receptacle types based on voltage and circuit characteristics, rather than solely focusing on the rated voltage of the connector itself. However, adhering to the rated voltage is always the safest approach and typically the expectation for proper electrical installations.
Among the supporting references, Google linked to this thread on Mike Holt's forum, wherein professional engineers and electrical contractors frequently debate the finer points of the NEC amongst themselves. Mike Holt teaches courses about the NEC, and I usually wind up studying his stuff when these obscure question arise.
As an aside, I used to know NFPA 79 (Electrical Standard for Industrial Machinery) inside and out. But that standard is very well written, and only a fraction of the size of the full NEC. The full National Electrical Code (NFPA 70) is more like the Holy Bible, IMHO -- voluminous, dense, and confusingly organized, with interpretations being heavily influenced by the preexisting beliefs of those doing the interpreting.
But back to a point made in the Mike Holt forum thread, I also recall seeing datasheets for NEMA connectors that specify a 600VAC max working voltage, regardless of the intended application voltage.
DLB
Re: Mark 7 by 220v
Post by DLB »
RFGuy wrote: Wed Jul 30, 2025 6:22 pm I am curious as to what the relevant section of the Mark 7 owner's manual says about conversion to 240V. Can someone post this please? Do they recommend cutting the 120V plug off. and replacing it? IF the plug is rated only 120V then perhaps a reason NOT to follow my earlier advice.
I hope the new Mark 7 is double insulated inside.
The Gen 1 Manual (mine is from the PowerPro Upgrade) says to "cut the old plug from the end of the Power Cord" and "install the appropriate 240-Volt plug." It goes on to say that in USA one should use a standard 15-Amp 250-Volt plug. And if you later need to operate on a 120-Volt circuit change the plug back to a 120-Volt plug.
The internal wiring is not significantly different than a conventional headstock, excepting those made long enough ago (1950's) that they did not include a ground. It is not double insulated as I understand the terminology. Both power wires are switched, which is consistent with at least later model Mark 5/V's.
RFGuy
Re: Mark 7 by 220v
Post by RFGuy »
Going back to what I think is the OP's concern...if he wants to keep the Mark 7 as-is, or rather like it was shipped from the factory - my solution was intended to give him that with some safety. Power cord locks and power lockouts are used all the time in the field. Alternatively, anyone can cut the plug off and install a new one and to many of us that is an easy solution for this problem and the one offered by Shopsmith because they want to avoid product liability lawsuits. I think the OP just wanted to make use of the closer connection to 240V on the wall, which also gives increased HP from the PowerPro, but while also maintaining his unit to easily go back to 120V at anytime. Maybe I am misreading the intent of the OP's post starting this thread. Also, I wasn't trying to start a debate on the NEC, though I am happy if others want to discuss it here. I am always happy to learn more. Remember I was an electrical helper, helping my Dad for over a decade as a child while he went on electrical contracting jobs. Even though I am an electrical engineer and have this electrician helper experience, I am eager to learn and/or refine what I think I know. NOT saying I know or remember much about the NEC, but I do remember many conversations with my Dad about the NEC and about practical applications. Everyone should follow the NEC and owner's manuals instructions as much as possible, BUT as long as one knows what they are doing, they know what the risks are and accept them, then practical application sometimes trumps the rules IMHO.
P.S.. I wouldn't trust anything AI summarizes from the internet. Google search has become almost useless today from what it was a few short years ago because of their adoption of AI. End rant. :(
P.P.S. I will agree with the above on NEMA and concede that the NEMA specifications are more about guiding towards a particular connection of voltage and amperage capacity. NOT written in stone though.
📶RF Guy
