Pen turning tip...
rcf
CA drying up
Post by rcf »
"In the past I have used 08X31 Special T CA Adhesive for pen blanks, from Woodcraft.com A bottle came with a pen making kit I purchased from the about four years ago. I used that one bottle until last week when it dried up."
If you put the CA in the freezer when it's not in use, it won't dry up.
"The road between friends is never long"
fjimp
Post by fjimp »
I knew that once upon a time. Thanks for assisting my feeble memory.
F. Jim Parks
Lakewood, Colorado:)
ryanbp01
Post by ryanbp01 »
About the comment on the barrel turning around the brass tube; did you first sand the tube before gluing it? I use 150 grit to thoroughly clean the tube, much the same way you would use emery cloth before sweating copper pipes.
BPR
cincinnati10
Post by cincinnati10 »
That's a good idea for specialty tubes that you don't use very often. But for 7mm tubes, I buy a lot of 10" tubes and extra bags of slimline tubes. Unless I am having great difficulty turning and blowing out a lot of blanks, it doesn't seem like it would be worth it to clean used tubes.
For those of you having tubes come unglued, I first scuff the outside of the tubes. This gives the glue gripping power. I always sand around the tube and not with the length.
I also coat both the tube and the inside of the blank. I use a toothpick to make sure the entire surface of the hole inside the blank is coated. I then run a bead of glue down the length of the tube and twist it as I insert it. In two years I haven't had a single tube come loose when I used this procedure.
nuhobby
Post by nuhobby »
This was a helpful thread!
I had got my 'training' on gluing the tubes in the blanks from the Pens From the Wood Lathe book sold by Shopsmith a while back. The author would 'spread' glue by coating a tube, inserting and retracting it at one end of the blank, then doing a final coated insertion at the other end of the blank. I have been doing this but lately I see with a well-sized hole the darn blank will scrape most of my epoxy off the tube during insertion. I like the tip on coating the inside of the blank (using a toothpick). Will try this soon.
Chris
