SS Pro Planer Blades Too High at Lowest Setting
piegolf
Re: SS Pro Planer Blades Too High at Lowest Setting
Post by piegolf »
Thanks for the help, I got the planer blades aligned to a new mark ~1/32 up from the original mark meaning my planer is finally working!
I measured the planed wood with digital calipers, it was the same thickness left to right and front to back so no issues there, I adjusted the depth gauge to match the thickness of the blades although it was already reasonably accurate.
depth gauge.jpg (188.14 KiB) Viewed 15186 times
Unfortunately I ran into another issue this time with the outfeed roller, even with the lowest tension, there are still marks in the board from it. On my planer, the outfeed roller is serrated and the infeed roller is smooth. On the shopsmith website, the outfeed roller they sell is smooth and the infeed roller is serrated, should i swap the infeed and outfeed rollers so that the serrated one is infeed and the smooth one is outfeed?
left screw.jpg (353.06 KiB) Viewed 15186 times
right screw.jpg (369.94 KiB) Viewed 15186 times
SS Mark V 520
SS Mark V 500 Shop Deputy with 50th anniversary headstock
SS SPTs: Bandsaw, Jigsaw, Jointer, Belt Sander, Strip Sander
SS Pro Planer
Pronouns: she/her
The hard roller should be on the infeed side and the smooth one on the outfeed side.
Makes no sense to 'dimple' the output.
