What is the Shopmate Maxi-Clamp used for ???
dynabase
Re: What is the Shopmate Maxi-Clamp used for ???
Post by dynabase »
azdustdevil wrote:I have a pristine copy of the manual for the maxi clamps.
I am looking for a Maxi-clamp manual. Paper or PDF?
Michael
terry
Post by terry »
does any one have a set of instructions for the maxi-clamp? I recently bought the clamps but the instructions were stuck together and useless.
azdustdevil@gmail.com
Try e-mailing!
tmomrik
Post by tmomrik »
To make it easier on anyone looking for the manual, I just uploaded a copy to http://vintagemachinery.org/pubs/detail.aspx?id=31885. I just picked up a used Mark V and the clamps were part of the package. I thought I was missing the rods until I realized the clamps were in an insert and found the rods and the manual.
edma194
Post by edma194 »
tmomrik wrote: Tue Nov 12, 2024 11:56 am To make it easier on anyone looking for the manual, I just uploaded a copy to http://vintagemachinery.org/pubs/detail.aspx?id=31885. I just picked up a used Mark V and the clamps were part of the package. I thought I was missing the rods until I realized the clamps were in an insert and found the rods and the manual.
Thanks for putting that online. Here's the manual from the old Magna version of the Maxi-Clamp system:
Magna Maxi-Clamp manual.pdf
(509.32 KiB) Downloaded 192 times
It should be noted that the link tmomrik provided is for the Maxi-Clamp. The link edma provided is mislabeled and is for the Universal Hold Down, the Model 10E and 10ER version from the early 1950's. There was also a Mark 5 version changing to the use of a 5/32" Allen Wrench instead of a 1/8" Allen Wrench. The Maxi-Clamp and Universal Hold Down are two very different clamping systems to do different jobs.
All SPT's & 2 Power Stations
edma194
Post by edma194 »
chapmanruss wrote: Fri Nov 15, 2024 12:32 pm It should be noted that the link tmomrik provided is for the Maxi-Clamp. The link edma provided is mislabeled and is for the Universal Hold Down, the Model 10E and 10ER version from the early 1950's. There was also a Mark 5 version changing to the use of a 5/32" Allen Wrench instead of a 1/8" Allen Wrench. The Maxi-Clamp and Universal Hold Down are two very different clamping systems to do different jobs.
Yes, my mistake, thanks for the correction. I have a Maxi-Clamp also, under the Shopmate name. I was focused on that instruction sheet and didn't even look at the box which was clearly labeled as a Universal Hold Down.
That's ok IMHO. Added maxi-clamp to my manual 'collection'. :>}
