Most Recent Project?
efmaron
Post by efmaron »
Paul,
That is a beautiful bowl, I agree with Chuck it looks like oak to me also. After all these years that I have had my SS I have done very little turning. I have a pile of 6"to 10" dia. branches behind my workshop from Live Oak trees that came down during a hurricane 4 yrs. ago that I have been saving for carvings. Maybe I will try my hand at making a few bowls. Good work Paul, thanks for the inspiration.
Eric, Sebring Fl.
john
Post by john »
Don's original post looks very much like the benches I stated to renew at the seniors' home, but never got back to. Also have my own that is leaning against a tree in my yard, in pieces. In the first instance, I was able to sand and refinish, but in the second, it requires new wood.
What is really frustrating is that new white oak would cost me about $45 + taxes, but one of the local big box stores had one on clear-out the other day for $49.95. I resisted, and will repair our existing one. Someday!
The bowl and pens look great and the dust filter reflects more good thinking to solve a problem.
Have fun
John
navycop
Post by navycop »
mbcabinetmaker,
I noticed in your pictures that you have a vacum hooked up and still have a lot of sawdust. I thought maybe I was doing something wrong with my setup because I was getting a lot of sawdust by the headstock. I guess if it is happening to a professional like you-then it will happen to a novice like me.:D
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
Thought I'd throw in a few pics of my latest project. It is going to be a coffee table with a top that raises 6" and swing about 14" over a couch. They call the things a convertible coffee table. It won't get completed for a couple of months it will be for Christmas. (The lift mechanism is in the cardboard box behind the table in the last photo)
first two leg parts.jpg (123.39 KiB) Viewed 3619 times
dry fitting the first end.jpg (138.72 KiB) Viewed 3611 times
inside view of legs and top panel.jpg (119.68 KiB) Viewed 3616 times
top of legs in dry fitting.jpg (127.97 KiB) Viewed 3612 times
idea of what it's going to look like.jpg (121.29 KiB) Viewed 3621 times
charlese wrote:Thought I'd throw in a few pics of my latest project. It is going to be a coffee table with a top that raises 6" and swing about 14" over a couch. They call the things a convertible coffee table. It won't get completed for a couple of months it will be for Christmas. (The lift mechanism is in the cardboard box behind the table in the last photo)
Once again you have inspired us!:)
etc92guy
Simple Things.....
Post by etc92guy »
.....I'm not in the league with the others here. Still learning and I figure before I make $200 worth of kindling I should practice by making jigs, fixtures and cabinets for the the shop. :p
I designed this drill holder from scratch. Used 3/4" dowels set at a 5 degree angle. The shelf is a dado with two screws in it from the back. The two holes at the top are so it can hang on peg board. Orientation of the components were based on the scrap ply I had available. I made two of these for the company a worked for temporarily.
[ATTACH]5688[/ATTACH]
This garden gate was my first attempt at half lap joints. I don't have a dado or shaper blade for the Mark V so this was done with the saw blade that produces a 1/8" kerf. Used Gorilla Outdoor glue and two 1 1/4" wood screws for each joint. Came out pretty square. My design must be good because summer is almost over and it's still together. This was for a client for my handyman business.
[ATTACH]5689[/ATTACH]
Each taught me a multitude of things. Especially when you don't have plans to go by.
Drill Holder-Small.jpg (41.75 KiB) Viewed 3680 times
Garden Gate-Small.jpg (84.81 KiB) Viewed 3675 times
Craig
Hartland, WI
-Mark 5 "Greenie" S/N 342238, Manuf. mmm/mmm 1957, Acq. Oct. 2008, Joiner S/N M067266
-10 E/ER(?) S/N Unknown, Joiner 4E S/N 40051
tom_k/mo
Post by tom_k/mo »
Here's something my son and I just finished for my twin granddaughters. Nothing fancy, but it works, and the girls took to it immediately and started filling it up. The graphics are 3-mil white sign vinyl which I drew in CorelDraw and cut with my Roland GX-24 cutter/plotter.
paul269
Post by paul269 »
efmaron wrote:Paul,
If you need some more inspiration check out this site.
http://www.woodturningonline.com/Turnin ... jects.html
joedw00
Post by joedw00 »
Paul
Thanks for the site. Looks like a lot of good info.:)
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
a1gutterman
Post by a1gutterman »
Nice joinery, Chuck!
Tim
