Stripping Old Finish
etc92guy
Post by etc92guy »
......and imagine what it does to the glue joints. Had that done in the past and picked up pieces.
All your labor is kinder and gentler.
Craig
Hartland, WI
-Mark 5 "Greenie" S/N 342238, Manuf. mmm/mmm 1957, Acq. Oct. 2008, Joiner S/N M067266
-10 E/ER(?) S/N Unknown, Joiner 4E S/N 40051
tnerb
Post by tnerb »
etc92guy wrote:......and imagine what it does to the glue joints. Had that done in the past and picked up pieces.
Yes. I had to glue several joints that had failed. Also, my lite sanding has turned into a major pain (in the fingers). The moulded mitered corners are not even. The dark tint hid this fact, but since I'll be using a lite stain with a clear finish, they would stand out like a sore thumb.
tnerb wrote:Yes. I had to glue several joints that had failed. Also, my lite sanding has turned into a major pain (in the fingers). The moulded mitered corners are not even. The dark tint hid this fact, but since I'll be using a lite stain with a clear finish, they would stand out like a sore thumb.
Are these tables old enough they would have been assembled with animal glue? I am guessing the newer yellow glue would not have failed fro stripping. Maybe I am saying I hope it wouldn't!
Pertaining to the molded mitered corners - Wood Putty can do wonders here! Not wood filler, but PUTTY! It comes in colors and two or more colors can be mixed to match the piece. Putty is applied after the finish and extra putty can be buffed away.
tnerb
Post by tnerb »
charlese wrote:Are these tables old enough they would have been assembled with animal glue? I am guessing the newer yellow glue would not have failed fro stripping. Maybe I am saying I hope it wouldn't!
The tables are old. but they're solid Oak. They've been in the Family for more years than I can remember. That's why I'm taking the trouble to re-finish them.
Don't know about the glue that was used, looks like it might be hide glue, but they sure used a lot of staples and nails in the rail to leg joints.
As far as the mitered corners, I didn't explain myself to well. What I meant to say was where the corners meet at the 45 degree angle, the routed profile on the egdes was not routed correctly. The corners looked fine under the dark finish, but when stripped, some were sanded across the opposite corner so the miters didn't meet at the joint.
Sorry to be so long winded.
Brent
tnerb wrote:Don't know about the glue that was used, looks like it might be hide glue, but they sure used a lot of staples and nails in the rail to leg joints.
As far as the mitered corners, I didn't explain myself to well. What I meant to say was where the corners meet at the 45 degree angle, the routed profile on the edges was not routed correctly. The corners looked fine under the dark finish, but when stripped, some were sanded across the opposite corner so the miters didn't meet at the joint.
Brent
Hi, Brent!
I'll bet is is hide glue that had loosened in the leg rail joints long ago from damp storage/hard use. Sounds to me the staples and nails were a later fix.
I understand the joints being sanded across the mitered edge. This is often a detail that is never noticed by others than the maker. I've done a couple of those myself, when failing to get the miters dead on.
tnerb
Post by tnerb »
charlese wrote:Hi, Brent!
Hi Chuck, been there and done that myself a time or two.
One problem of being a woodworker. We tend to notice things like that and want them as good as we can get them.
Brent
