blade guard
fjimp wrote:So Dusty is this her way of enforcing the topic at hand:confused:
I think the answer is probably yes, even though blade guards and riving knife were not a point of discussion. The accident to which she refers was the product of using the shaper with no feather boards (hold downs). The damage was done not by a blade but rather a piece of very fast moving oak. That was in the year 1976. I remember because she mentions it every now and then. She doesn't nag about it, she just slips it into the conversation every now and then.
beeg
Post by beeg »
OH it was in 1976, then it does knot count anymore. That was in the PRE-Retirement years. :D
a1gutterman
Post by a1gutterman »
jonesuh,
Do knot forget to teach him about push sticks and blocks!
Dusty,
dusty wrote:...It was then that she warned, "You ever do this again, there will be NO Shopsmith where I live". I sorta think she meant it. But she can't enforce that, can she?:eek:
Well, you can knot control what she keeps where she lives...after she moves (just kidding:) )!
Tim
navycop
Post by navycop »
Back in '07 while I was working as Naval Base police. My Captian told me I was going to GITMO. He told me on a monday and said I was leaving on the following wednesday. At this time I had my bathrm all tore apart. The toliet, vanity, baseboards were gone. I was retiling it. So I was in the garage cutting new baseboard, at 0100 in the morning. When a piece of wood got stuck between the blade and the insert. I didn't have a guard on because I couldn't get the riviting knives to line up with the blade (I had mentioned this in a previous post). To make a long story short. Anyway I am half an index finger shorter on my left hand. Needless to say I didn't go to GITMO I had to go to Portsmouth Naval Hosp for rehab....
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
navycop
Post by navycop »
iclark
Post by iclark »
a1gutterman wrote:jonesuh,
including the part about knowing where your fingers will be if the push stick breaks or the wood kicks out from under the push block (most plastic push blocks cut through much faster than wood).
oh, and don't forget the dust mask explanation.
Ivan
ER10 awaiting restoration
robinson46176
Post by robinson46176 »
iclark wrote:including the part about knowing where your fingers will be if the push stick breaks or the wood kicks out from under the push block (most plastic push blocks cut through much faster than wood).Ivan
This is a really important point. :eek:
flyslinger
Post by flyslinger »
Accidents seem to happen when "YOU THINK YOU'RE GOOD" and loose respect for the machine you are using.
