How about a piece of all-thread rod instead of the dowel. Once you get things set just how you want them, trim off any excess, and spraypaint the rod black.JPG40504 wrote:The dowel is used as a 'prop'. If the balance point aims the speaker too low, the dowel is positioned between the back of the speaker and the ceiling. If too high, the dowel is positioned between the top of the speaker and the ceiling.
If that speaker handles too much bass, the dowel might vibrate out of position(fall). Then the music would really swing!:rolleyes:
An adjustable brace attached to an edge of both boards would be 'better' than a prop(but require much more 'effort').[as well as wider boards]
Ceiling Speaker mount...
