Mounting bases
8iowa
Post by 8iowa »
The overall dimensions are 10" x 8", which which is approximately the same as the aluminum bases. However, I did not angle the feet as on the aluminum base. The feet are countersunk and drilled to accept a 1/4" carriage bolt. I certainly recommend bolting the base down before attempting to mount a SPT.
As I built them I made some changes. I will now have to go back to my drawing and modify it. If you are going to mount a jointer with the dust port attached, you will have to cut a relief angle on the side of the cross piece in order to obtain clearance.
Nifty design, 8! Didja make an extra one to hole the extension table when not in use?
