Identify this machine - Please?
judaspre1982
Post by judaspre1982 »
judaspre1982
jalt
Post by jalt »
I also thought that was a "rough edge" at first, but if you look again you'll see that it is just a shadow from the blade.
PG-Zac
Post by PG-Zac »
Thanks for the responses.
South Africa doesn't have 110V, so I'm sure the motor is a 220V - that's normal for us.
I intend keeping a photo journal of the renovation progress, and will be posting here if the members would like me to.
I haven't yet tested the motor 'cos it feels like there is still a drive belt attached to the main spindle. I want to strip off all belts before testing the motor just in case something is jammed. I'll post info on the motor in a few days once I get the housing open.
Yeah, Shopsmith unfortunately is pretty rare in S.A. which could make sourcing new parts quite a mission.
wa2crk
Post by wa2crk »
On second look I think you guys are correct. Must be one of those "Optical Delusions"
Bill
beeg
Post by beeg »
PG-Zac wrote:I intend keeping a photo journal of the renovation progress, and will be posting here if the members would like me to.
We wood be VERY grateful is ya wood do that. There's a lot of info here about restoring, so just ask or do a search.
iclark
Post by iclark »
yes, definitely lots of interested people here.
as farmer points out, there is an interest in what you find behind the speed changer when you take the belt cover off. those 2 holes are interesting.
it may be an optical illusion but it looks like the vent plate had to be removed because the lower drive shaft is so far off center.
any idea why there is another hole in the belt cover below the 2 drive shaft holes? it almost looks like it would line up with the motor shaft.
good luck on your restoration. we are looking forward to it.
Ivan
ER10 awaiting restoration
iclark wrote:yes, definitely lots of interested people here.
Ivan
That 'hole' is normal for a mark 5. It's purpose was to provide access to the floating sheave lubrication hole. It was not too effective!
iclark
Post by iclark »
JPG40504 wrote:That 'hole' is normal for a mark 5. It's purpose was to provide access to the floating sheave lubrication hole. It was not too effective!
jpg,
thanks for the info.
I did go back and look at mickyd's greenie restoration thread before I asked. since the hole was not there for his, would its presence here help any to narrow down the birth date for this one?
Ivan
mickyd
Post by mickyd »
'Normal"? Is my 5 abnormal?
[ATTACH]8003[/ATTACH]
Sunny San Diego
